kipper
posted on 23/8/12 at 03:54 PM |
nissan primera.
Hi guys , I am hoping the collective can offer a solution to a problem I have with my Primera's wipers.
The problem is when I turn on the wipers they work as they should on both speed's BUT, they wont turn off again.
I can make them turn off by flicking the ignition switch of and on again then park them with the nudge facility.
I can see one day me flicking the ignition off and the steering lock dropping in...........PANIC!
I put it to the learned collective
Regards Denis.
Where did that go?
maccmike
posted on 23/8/12 at 03:56 PM |
probably a relay
ian locostzx9rc2
posted on 23/8/12 at 04:51 PM |
If its a 2002 onwards it could be the wiper motor as it was quite a common problem when i worked at nissan...l
iceman26
posted on 23/8/12 at 05:07 PM |
wiper motor internal fault
clairetoo
posted on 23/8/12 at 06:06 PM |
I had a similar problem with the wipers on my Fury - turned out to be the park switch on the motor .
Its cuz I is blond , innit
Claire xx
Will weld for food......
kipper
posted on 24/8/12 at 07:10 AM |
Thanks fella's
I will try to find a second hand motor.
Denis.
Where did that go?
