Markymark
posted on 14/9/12 at 07:45 PM |
VW Golf rear brakes on Sierra hubs
Hi All
Thinking about fitting VW golf calipers to the back of my Sierra based Fury that I'm building.
Has anybody done this and if so did you use the standard Sierra discs?
Lots of pics would be very useful
Many thanks in advance
Mark
[Edited on 15/9/12 by Markymark]
Wadders
posted on 14/9/12 at 07:53 PM |
Not saying it will apply to your particular build, but i found problems with clearance under 13" wheels
using golf calipers, sold them in the end and used pug 106 calipers which are quite compact and light
the handbrake mechanism was also in a more convenient place on the pug items.
Al.
Golf Calipers
[img]
[/img]
Pug calipers
[img]
[/img]
[Edited on 14/9/12 by Wadders]
Mr C
posted on 14/9/12 at 10:49 PM |
I've got them fitted to my v-storm, if you use 252mm discs you will get about 10mm of pad overhang, I searched high and low for another set of
discs to irradicate this and ended up fitting 272mm sierra RS500 discs now I've a few mm of pad underhang as there is a machined groove between
the face of the disc and the bell. Less of a problem than the overhang though a niggling issue all the same. If I keep the car I'll swap them
for some hispecs with a separate handbrake caliper.
Girl walks into a bar and asks for a double entendre, so the barman gave her one
