MsD
| posted on 14/10/12 at 01:42 PM |
Front brake flexi's and the IVA.
Following on from this thread a few years ago... http://locostbuilders.co.uk/viewthread.php?tid=122913
Is it acceptable to attach the flexi's to the wishbones/ wingstays? And is it acceptable to put a rubber sleeve over the pipe where it contacts
with the wishbones?
I've tried all the usual loops/ twists in the pipe to try and get clearance on the flexi's but im not having much luck.
Any help appreciated as usual
Thanks, Mark.
renetom
| posted on 15/10/12 at 06:44 AM |
pipes
Hi
We just cut a piece of fuel line tube slit it put it over the flexy then cable tied it
to the wing brackets which move the same , use 2 cable ties in cross formation otherwise it will pull the flexy to one side.
keep the sharp side of the ties on the inside , where he can't get his ball in (sharp edges), better still use the flat cable ties.
IVA man was happy with that ( Mitcham Dec 11)
definitely not to the wishbones
good luck
René
[Edited on 15/10/12 by renetom]
