posted on 15/10/12 at 12:10 PM |
Rear brake shoes - mental blank! [SORTED]
I'm in the process of putting all the components back onto the rear-right back drum brake - and I can't remember which brake shoe goes
where! The metal part of the shoes are identical, but the actual friction material is mounted in a different position on each one. Clearly one is
meant to go on the forward side, and the other on the back. Trouble is - I can't remember which is which...
Can anyone confirm that the ones in the picture are the correct way round? Brake cylinder at the top, right-hand (driver's) side, laid out as
if you'd just taken the drum off and were looking in at the shoes.
![](/galpreviews/shoes.JPG) ![brake shoes](/gallery/shoes.JPG) brake shoes
[Edited on 15/10/12 by David Jenkins]
adithorp
posted on 15/10/12 at 12:28 PM |
As you'e got themin the picture is the O/S. The leading edge is the end of the shoe with the longer plain bit.
http://jpsc.org.uk/forum/
posted on 15/10/12 at 12:29 PM |
Excellent - that's all I need to know!
Thanks.
