froggy
| posted on 17/10/12 at 07:50 AM |
Alternative lower ball joint sierra upright ?
I'm changing my front uprights and need to find a two pin bottom ball joint like the old fiesta type to suit my lower arms , anyone used
anything other than the maxi type ?
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
Bluemoon
| posted on 17/10/12 at 09:00 AM |
Humm you do need to think about where the loads are, the maxi ball joint is not ideal for the lower wishbones on a locost ect. The suspension is
trying to pop out the ball (as the shock is normally putting it's load on to the end of the wishbone).. We seem to get way with it but I think
this is not the original function in the maxi ball joint.. So what you choose will depend on your application..
[Edited on 17/10/12 by Bluemoon]
froggy
| posted on 17/10/12 at 09:02 AM |
I'm using an early fiesta type ball joint at the moment so need something similar with a two pin fitting
