Minicooper
| posted on 7/11/12 at 04:39 PM |
Rear Brake Disc Sierra Conversion
When doing a sierra rear drum brake conversion to disc brakes, what brake disc is used, I believe it is 240mm solid fiesta/escort front brake disc, is
this right?
These any good?
Eicher Front Brake Disc for Ford Orion, Fiesta, Escort
Does the hub beneath the drum need machining to reduce the diameter to fit inside the fiesta/escort disc?
[Edited on 7/11/12 by Minicooper]
big-vee-twin
| posted on 7/11/12 at 05:00 PM |
I used a standard Sierra disc with Sierra calipers, hub needs turning down to fit within bell to 134mm.
[img]
.jpg) .jpg) 134mm Drive Flange
[/img]
[img]
  Rear Brakes
[/img]
[img]
  Rear caliper conversion
[/img]
[Edited on 7/11/12 by big-vee-twin]
http://www.triangleltd.com
BangedupTiger
| posted on 7/11/12 at 06:41 PM |
I'm about to remove my sierra front brakes to fit my wilwoods.
Would my current sierra setup fit on the rear? discs are vented, seems a shame not to use them on the back if they will fit.
