jimmyjonga
| posted on 24/9/04 at 02:12 PM |
2 peice prop - diy???
hi
using a zx9r lump and i realise i need a 2 peice prop with a centre bearing, is this something that i can modifyfrom a suitable item or is it best i
leave it to the experts, ie buy one??
psi have got access to decent engineering equipment
pps - got sunburn yesterday blind tacking - would not recommend it!
james
locogeoff
| posted on 24/9/04 at 02:23 PM |
Blind Tacking
I ended up looking like I had been dookin fer chips after tacking up my workbench
Not angry, just sorta looked like that
Sorry no info on the propshaft!
DaveFJ
| posted on 24/9/04 at 02:56 PM |
Unless you have the equipment available to dynamically balance it properly i would leave it to the experts (they aren't really that expensive)
Dave
jimmyjonga
| posted on 24/9/04 at 02:58 PM |
no matter how it is made i wont be able to balance the thing...... anyone know some good suppliers???
james
Jon Ison
| posted on 24/9/04 at 03:33 PM |
i used Henry fords best.....
James
| posted on 24/9/04 at 04:44 PM |
James,
I got burnt Sunday eve tacking bits together. Face was hurting for 2 days!
I've just ordered my prop from this guy:
http://www.autoprop.co.uk
Seemed really friendly/helpful and best quote I got. He's on holiday this week though.
These guys were recommended to me by someone at Mclaren:
www.propshaftservices.co.uk
but took me 3/4 attempts to get them to answer the phone and then they weren't too helpful/friendly. (or cheap )
HTH,
James
Liam
| posted on 24/9/04 at 04:48 PM |
Volvo is your friend!
I have a volvo breaker near me and they have perfect donor propshafts for becs (off a 2 litre 740 or 840 or something i think).
Joints are rebuildable meaning you can easily replace the rear yoke with one that fits a ford diff/axle. It has a centre bearing that fits nicely
near the front of the tunnel, and a sliding joint. It's then just a case of chopping the front part of the shaft for length and fitting your
sprocket adaptor. Did this ourselves on my mates blade westy by hammering on a cds sleve. It can only go on straight - had no vibration problems at
130 mph on the track. Alternatively get the volvo prop modded by a pro, but that'll still be much cheaper than a custom shaft.
Liam
JB
| posted on 27/9/04 at 07:00 PM |
DIY Props
Unless you know what you are doing then leave it to the experts. Dunning And Fairbank in Leeds are also good.
A good source of 2 piece props is Ford as as all the service bits are cheap.
It is actually possible to do your own props, a lathe and clock makes the job very easy but careful use of a hacksaw, grinder and a pen will get the
job done.
Also if the job is done correctly then 90% of the time balance wieghts are not required, but you do not know this until it has been on a balancing
machine. However if you check the shaft for true running after welding and total run out is less than 0.1mm on the tube I would be confident not to
balance.
John
