Daddylonglegs
| posted on 20/1/13 at 08:07 PM |
Brake M/C Servicing Kit
Following on from my recent M/C posts, does anyone know if the 22.2mm bore Sierra M/C servicing kits are suitable for all the M/Cs?
AFAIK there are 2 main types of 22-type M/Cs, mine is the cast type and looking at all the pictures I can see for the seal kits they look like the
same as the seals I have on mine. I can't believe that there would be many different ones for them so would it be worth the risk buying? Looking
on eBay, there seems to be a few kits that will fit dozens of different sierra model M/Cs so I'm guessing they should be OK.
Anyone with any experience of these kits that could give me any pointers would be good
Thanks guys 'n gals
| posted on 20/1/13 at 08:38 PM |
The fact is there are few types of repair kit because kits are not available for most Sierra master cylinders so unless you have the Girling
cast type used on the earlier models ..........
Daddylonglegs
| posted on 20/1/13 at 08:58 PM |
Mine is the cast type as shown below:
Seal kit is as shown in pic:
IIRC the donor I got most of the stuff off was a 1986 Sierra Saloon.
[Edited on 20/1/13 by Daddylonglegs]
