pekwah1
| posted on 7/2/13 at 06:38 PM |
Escort quick rack
Hi Guys,
What's the ratio on a standard escort steering rack, and what is a good ratio for a quick rack if i'm going to change?
I'm seeing loads of 2.9, 2.4, 2.2
Just after some opinions!
philw
| posted on 7/2/13 at 07:01 PM |
IIRC it's 3.5ish standard, I had 2.4 which was good for road and some track use, some say 2.2 is a bit quick for road use(but you would get used
to it I suppose,), a friend had a 1.7 for track only
[Edited on 7/2/2013 by philw]
Must try harder
| posted on 7/2/13 at 07:19 PM |
I have a 2.9 rack in my car which I think is quick enough for the road especially when used with a smallish steering wheel
adithorp
| posted on 7/2/13 at 09:04 PM |
Standard is 3.5. I had a 2.9 initially on my Fury but after 2 years switched to a 2.4. The 2.9 was fine in normal road use but the 2.4 is much better,
especially on track or twisty roads. Much prefer the 2.4.
Beware of some 2.9 racks; Apparently there are some that are 3.5 ratio gears but with lock stops reducing the movement to 2.9. I checked mine and it
was a true 2.9 but trust the source of the info so there must be some out there.
http://jpsc.org.uk/forum/
pekwah1
| posted on 8/2/13 at 07:50 PM |
Would this be any good, seems a good price.....
Mk1 mk2 Escort Rs2000 Mexico Quick Steering Rack 2.4 | eBay
