andyharding
| posted on 27/9/04 at 04:29 PM |
Steering column and Zetec engine
Anyone got any ideas how to get around the oil filter on the Zetec?
dozracing
| posted on 27/9/04 at 04:40 PM |
Move the oil filter, or use a short one. Ask raceline www.raceline.co.uk as they can supply.
Kind regards,
Darren
andyharding
| posted on 27/9/04 at 04:42 PM |
Thanks, will look into this.
How's my bodywork coming on?
zetec
| posted on 27/9/04 at 04:49 PM |
I mounted my engine slightly off the centre line of the chassis and tilted up slightly on the induction side, just enough to use a standard Ford
Mondeo filter (bigger the better?), also gives a bit more room when fitting carbs or throttle boddies. Only needs to be over by about 1"
compared to the gearbox output flange. Or as said smaller or remote filter.
garage19
| posted on 27/9/04 at 09:49 PM |
I mounted mine on the centre line and at the right height/incline for the steering shaft to pass right across the face of the oil filter mount. Doh!
Bout 25mm clearance.
Thought about remote filter but not sure ther is even enough room for take off plate if you take in account slight engine movement.
Now in the process of building a two peice steering shaft with centre bearing!
Any one know which donor car I can get some good UJs out of?
DC
Mix
| posted on 28/9/04 at 07:25 AM |
Halfrauds oil filter Pt no HOF238 is only 60mm long. I found one in Halfrauds and was charged £0.01 as it was old stock
Fram equivalent is Pt no CA3121.
Mick
James
| posted on 28/9/04 at 02:49 PM |
DC
Was poking around some power steering Sierras in the scrappy recently. They seem to have an extra section with an extra UJ- would the UJs from here be
any use?
HTH,
James
locoboy
| posted on 28/9/04 at 03:20 PM |
bedford rascal type vans have a uj in the steering column thats accessable from the inside of the cabin, its about mid shin height if you were sitting
in the driving seat.
1 x Hacksaw and you should be ok. Not sure on the diameter they will take though but from a quick inspection they look ok.
Locoboy
givemethebighammer
| posted on 29/9/04 at 02:30 PM |
These should all fit and are much shorter than the original (just change it more often)
Halfords HOF 238
Crossland 659 (Dunnell standard fitment)
FRAM PH2874
Coopers 107X
Believe these are all from Renault 4 or 5
JUST CHECK THE FILTER YOU FIT HAS THE SPRING VALVE IN IT - you don't want to trash your engine
I have fitted Crossland one seems loads of the Westy people do to.
andyharding
| posted on 29/9/04 at 02:33 PM |
Thanks for all the suggestions guys. I'll have a hack around at the weekend and see how I go.
