jimmyjonga
| posted on 28/9/04 at 01:50 PM |
coilover length?
hi
buliding a capri tracked car, ie capri axle and intend to make the front wishbones a little wider to suit, but what open/closed length coil overs
should i be using.
i searched but could not find a definate answer
james
James
| posted on 28/9/04 at 02:35 PM |
If you change the relative (to each other) wishbone lengths then you will be changing the wishbone geometry. Be careful with this as you may not be
changing it for the better!
James
dozracing
| posted on 28/9/04 at 03:21 PM |
If you view my PDF drawing on www.gtstuning.co.uk in the shock kit section you will find what you need.
As James says you ought to be careful/creative about how you position the shocks on a wider track.
Kind regards,
Darren
