Sebastian
posted on 2/3/13 at 04:09 PM |
Luego lighting problems.
Hi Guys,
We have a problem with connecting the lights on our Viento.
Problem is:
We have the original Viento loom with relaypack, everything on the dash works fine but we can't get the lights working.
There are 3 wires for the lights that come from the relay pack which says connect to switches, 1 red wire, 1 blue/red and 1 blue/white, we want the
main beam to work from stalk on the colomn and the dip and side lights from a switch.
There is positve feed on the brown wire that goes into the top relay (side lights) and connects to the other 2 relay's.
We have a switch with 3 points, 1 for possitive 1 for dip and 1 for side lights, although that's what we think.
If i connect the possitive to the switch ans the blue/red to the other point the dip beam works but we can't get the side lights (and tail
lights) working and the main beam doesn't responde if i connect the wire direct to the colomn stalk.
I think we make an error in thinking but what
Tried new relay's but no difference.
Hope you guys can help.
SteveWallace
posted on 2/3/13 at 10:34 PM |
This is how my Viento is wired using Sierra stalks for main and dipped lights. The loom was supplied by Luego but is a Premier Loom. Depending on
which stalks you are using it will need to be wired as switched earth or switched live. I know that what I have does not exactly match yours, but
hopefully it will be of some help. Note that a 'P' next to the wire colour means that its the Premier Loom colour, an 'S'
means that its the Sierra colour
![](http://locostbuilders.co.uk/upload/Headlight tail and fog 22 Nov 2012.JPG)
Sebastian
posted on 3/3/13 at 10:44 AM |
I am not using the sierra stalks for the dip an sidelights, only the main (high)beam is on the stalk.
So do i have to connect a earth to the switch and on the other 2 pins the wire for the dip an sidelights that come out of the relaypack?
