Author: Subject: MX5 Gearbox adapter
rdodger
posted on 6/3/13 at 09:36 PM Reply With Quote
MX5 Gearbox adapter
I have been wondering if any one does a gearbox adapter plate to mate Ford engines Zetec or Duratec to MK1/2 gearboxes?
MX5 5 speed gearboxes are pretty worthless (less than £50. I can't give my 5 spd away!) as they rarely break and the 6 speed is quite rare but available for less than £400. I paid £250 for my 6spd.
The 6 speed box will take over 300bhp without any bother.
I have used the 1.8 MX5 engine with a supercharger but they are an iron block and not that great for NA tuning.
It would seem like a good idea as the ratios are better than Sierra, especially the 6 speed.
The only down side might be they are a little wider than a type 9.
inkafone
posted on 6/3/13 at 09:51 PM Reply With Quote
Mk3 MX5 uses the duratec so maybe the Mk3 Mx5 gearbox is the same as previous generations with a different bellhousing?? That would be too easy though..........
rdodger
posted on 6/3/13 at 10:03 PM Reply With Quote
The mk1/2 has an integral bellhousing as does the mk3.
chillis
posted on 7/3/13 at 10:11 AM Reply With Quote
Duratec/mk3 mx5 and zetec are totally different belhousing patterns.
MK1/2 MX5 is totally different belhousing pattern to any of the Fords.
I've been trying to adapt a MK1 mx5 gearbox to a zetec but for what it will cost you can buy a type 9 rebuilt with close ratio gears.
Cheaper still buy a MK1/2 MX5 engine to go with the mx5 gearbox which is what I'm now doing.
Never under estimate the ingenuity of an idiot!
