Author: Subject: pedal box
wheelsinsteadofhooves
posted on 30/9/04 at 03:55 PM Reply With Quote
pedal box
hi,
has anyone anything to say on the subject of pedal boxes for a locost? how about the ones by luego or car builder solutions? any other options? think would prefer floor mounted "sports" box but pricy option, unless anyone knows better.
thanks for any input
GasGasGas
posted on 30/9/04 at 04:42 PM Reply With Quote
floor mounted "sports" box pricy option
Try Darren @ GTS he does a weld in pedal set for a Locost cheaply
locoboy
posted on 30/9/04 at 09:16 PM Reply With Quote
if you can find it on his website your a better man than me.
GTS LINK
Locoboy
posted on 30/9/04 at 09:28 PM Reply With Quote
mine are nothing special, but i built them from scrap in a few hours. 3mm strip bent to make brackets, and inch square tube for the actual pedals. 19mm round to hold the clutch and throttle cables, and a cut up servo mechanism to link the brake up. Cost nothing and has worked well when braking in anger (in my driveway, officer!)
robinbastd
posted on 30/9/04 at 09:49 PM Reply With Quote
Col,
Halfway down the chassis page on GTS website.
Ian
http://smuttygifts.com/
posted on 1/10/04 at 08:31 AM Reply With Quote
cool, gts setup seems decent value on first impression. anyone used one? also is gts still going strong, heard someone with similar name having difficulties but may be way off. sorry to anyone if i am.
quite like the idea of building my own.....
Mave
posted on 1/10/04 at 03:20 PM Reply With Quote
Build them yourself! It's really easy (well, if you can weld). Look at mine (inspired by the Ultima pedals, and GTS aswell)
derf
posted on 1/10/04 at 05:22 PM Reply With Quote
Mave that is probably the coolest pedal design I've ever seen, real adjustable pedals. My only though on their design is that moving the pedal in or out, wouldnt thatchange the pedal height, when it is out or pressed in, some where along
I'm also assuming that you lock the pedal in position with nuts.
Mave
posted on 2/10/04 at 10:11 AM Reply With Quote
That change in length is so small; you won't notice.
Oh, and yes; they will be locked by some bolts....
MikeP
posted on 2/10/04 at 01:17 PM Reply With Quote
Hi Mave, not to be critical - I really like your pedals, especially your adjustable height pedal pads.
Fred Puhn, in his "Brake Handbook" says: "A good pedal design will not have welds completely across the arms, particularly at the pivots." (pg66). He's concerned about stress risers at the critcal parts of the arm.
Anyone that's planning to copy your work should keep in mind that their welding must be very, very good on the brake pedal.
A alternate approach for a simlar design could attach the pivot tubes going only partially through the arm tube. The weld goes around that tube instead of across the arm, and the bits are arranged so that the joined parts are is under compression during braking. He's got some pictures of pedals like that on pg 67.
type 907
posted on 2/10/04 at 03:27 PM Reply With Quote
Or like this !
There not quite finished yet, I'v still got to drill loads of holes in them. (Tee Hee)
I'v sorted the testing of them. My mate is going to sit in the pasinger seat,
and we'll scream down "Kettle Hill" (local landmark), and test them 20m from the 90 deg left at the bottom.
Too much is just enough
andylancaster3000
posted on 7/10/04 at 03:43 PM Reply With Quote
Pedals...
Floor mounted or hanging???
PioneerX
posted on 19/10/04 at 12:42 PM Reply With Quote
Floor mounted, definatly. I have the GTS set (from when they just started selling them and I'm very happy, they have a great look and feel about them. I have looked through my rather extencive set of photos for my build and cant find one of the pedals in the car. If I get time I will take one and post it.
phelpsa
posted on 20/10/04 at 08:53 PM Reply With Quote
We're making a top mount pedal box, one for go, one for stop!! No clutch pedal as that will be mounted on the gear stick. We thought it would be easier as we would not have to cut huge holes in a 3mm steeld bulk head.
