doughie
| posted on 10/4/13 at 08:42 AM |
Rack Mounts?
Hi, looking at the 'book' plan for mounts - what issues should i be aware of?
Are they strong enough?
Are they in the right place?
etc...
Building a 'book' chassis - escort rack with cortina uprights... (very slowly!)
Much thanks in advance!
mark chandler
| posted on 10/4/13 at 11:26 AM |
Needs a diagonal brace to stop them falling over, think about the left/right loading and it is trying to twist off the base.
Also have a search for bump steer, lots in this but very simply tack in place, dummy assemble the bones and hubs then position through trial and
error.
[Edited on 10/4/13 by mark chandler]
doughie
| posted on 13/4/13 at 09:42 AM |
  steering rack upper view
thanks for your reply Mark - just mocking up the placement of the rack - reading around 'bump steer' issues, i can't get the rack
straight in the horizontal as i increased the backwards slope of the front chassis uprights to get a decent caster angle...
has anyone else had this issue? will this be ok in practice?
all help gratefully received
SteveMX5
| posted on 13/4/13 at 10:35 AM |
I found the book mount angles and position to be fine. I beefed them up a bit by using 40x4 mild steel bar as 3mm seemed a bit flimsy. Did consider an
additional diagonal on the rear elevation but doesn't look like it needs it.
phelpsa
| posted on 13/4/13 at 10:57 AM |
My 'Ackerman Eye' says your fore and aft positioning looks pretty good!
