Litemoth
| posted on 13/4/13 at 03:23 PM |
Sierra Driveshaft Shortening..Writeup
I'm aware that having a shaft made to size, new by proper engineers is the way to go but I chose to take the path of certain destruction...cut
'n' shut driveshafts
This is what I did:
Set the shaft ends in diff and hub to get finished length:
Marked, cut and weld prepped the shafts:
Placed shafts in interrupted vee-block and mounted in 10T press to maintain some degree of straightness and to correct any 'pull' as I
built the weld. I haven't got a picture of the welding and dressing as my camera and sparky grindy stuff don't mix.
Crucial bit was the welding though, Arc welded, slowly built-up, part vertical aspect with 29/9 rods. I've used these rods in industry on
difficult steels and high stress rotating shafts and they produce very crack resistant and reliable joints.
Finished shafts completed with can/boot sets from Ford dealer - note two sizes of can available 1058426 (smaller) 1058427 (larger approx. 65mm across
i/d of can)
trikerneil
| posted on 13/4/13 at 04:12 PM |
I made shrink fit sleeves when I did mine. Then MIG'ed the whole lot up while it was still all hot.
Been OK for 8 years now, but then I'm only putting about 90 HP through them.
Neil
ACE Cafe - Just say No.
