Author: Subject: Brake line fittings
Sierra
posted on 18/4/13 at 11:12 AM Reply With Quote
Brake line fittings
Hi all I've now moved on to 2 master cylinders with 1 outlet each so I need to join the rear brake lines some how before connecting to the master cylinder.
Question is could I fit a 4 way fitting directly to the master cylinder then connect the 2 rear brake lines to the sides and pressure switch to the top.
The reason I'm thinking of doing it this way is that it'll save me having to buy another section of line and the get it flared ect.
