Author: Subject: What size hole for 13.1 spline diameter wheel studs
dave_424
posted on 18/4/13 at 09:52 PM Reply With Quote
Hi, I am trying to find out what size hole is needed for a set of wheel studs that are listed as having a 13.1 spline diameter. If I had them with me I would do the measuring bit myself but I don't and want to get this drawing out to the laser cutters as soon as possible.
Dave
rodgling
posted on 18/4/13 at 10:06 PM Reply With Quote
I used a 14mm hole for 14.3 mm studs, which turned out to be v v tight. I would go for .1 or .2mm difference.
dave_424
posted on 18/4/13 at 10:13 PM Reply With Quote
Cheers, went with 12.9 which should give them a good bite into the hub.
madteg
posted on 19/4/13 at 07:30 AM Reply With Quote
I would go for a 13mm but use a pillar drill, do a trail hole in a scrap piece of steal the same thickness. That way you could use a common drill size and nothing lost.
