itsawindupuk
| posted on 23/4/13 at 07:59 PM |
Rod ends with bushes, where?
hi everyone, im designing a rear coilover suspension for my MGB. Im looking for rod ends where you can insert rubber or poly bushes, as i dont want to
use the normal ones as its a road car and may be too noisy and also i heard they can wear quickly.
Any thoughts?
Adam
minitici
| posted on 24/4/13 at 10:12 AM |
Make your own?
Or buy these
Linky
[Edited on 24/4/13 by minitici]
itsawindupuk
| posted on 24/4/13 at 02:14 PM |
Cor they aren't cheap lol. I need 8! If I wanted to make my own is it simply a case of cutting some tube to the correct length and welding it to
the end of a longer tube?
Adam
Andy S
| posted on 24/4/13 at 05:23 PM |
IYHTAT - step away from the hacksaw
| posted on 24/4/13 at 06:16 PM |
Adam
Yes it is, just make sure you size the tube and bushes to give a slight interference fit and make your crush tubes from stainless steel.
