dodgyroger
posted on 4/10/04 at 06:47 PM |
Passed SVA today at Norwich despite failing CAT test!
Well I managed to get my MK Indy-blade through SVA today at Norwich despite failing the CAT test. I have a 1997 Fireblade RRV engine and CAT fitted
along with Snoopy’s fish tank valve emissions system. The slow idle test passed fine but I failed the fast idle test with a 0.85 CO2 reading (It needs
to be max 0.3). No problem said the SVA inspector, you can have 20 mins to sort this out at the end - Fine I thought, a couple of valve tweaks should
do it. After all, HC and Lambda were fine at 0 and 1.02 respectively.
However at the end of the test, and after some deliberation with his colleague, the inspector said that a retest of the emissions would not be
necessary on the grounds that the MK Indy is not listed as a known car in the emissions data base, so the default situation is to allow a more lenient
3.5% CO2 figure - So I passed emissions afterall and presumably would have got away with not having a CAT at all!
I also failed on two other things which were rectified and retested in about 30 mins. 1) The off side mirror needed raising up a bit; 2) The bottom
edge of the dash was too sharp so I cut a slit in some rubber fuel pipe and fitted that.
It then passed so I’m right chuffed. I got absolutely soaked driving to the test though and had to stop half way to bail the car out but it was worth
it.
Roger
http://www.dodgyroger.com/locost
Mk-Ninja
posted on 4/10/04 at 07:08 PM |
Well done you jamy bugger. ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
I'm sure I've got one, just don't know where I've put it
jacko
SVA
HI Roger congratulations with the pass another indy on the road jacko
type 907
posted on 4/10/04 at 07:54 PM |
Well done Roger.
Could this be another car at the next suffolk meet ?
Paul G
Too much is just enough
scotlad
posted on 4/10/04 at 09:30 PM |
Fantastic news Roger! well done. shame you've missed most of the 'decent' weather . was out today in mine when it was howling a
gale- brrrrrrr![](/images//smilies/sad.gif)
posted on 4/10/04 at 10:43 PM |
Good show chaps.
I think we all ought to go to Norwich for sva on the strength of that. A tester who uses his own discretion has got to be a good thing. Any bike
engined car should get through using that logic if the bike wasn't required to have a cat.
[Edited on 4/10/04 by Peteff]
subk2002
posted on 4/10/04 at 11:07 PM |
Well done ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
tractorboy
posted on 5/10/04 at 03:35 PM |
well done roger . give me a shout if you fancy a blast sometime when your all registered and road legal.im just down the road in burwell.
r3nuf
posted on 5/10/04 at 05:41 PM |
Nice one Roger!
Think i just saw you on the A14 at 17:00hrs near Stowmarket today?
A 'G' Reg i do believe?!
Looks Great
Gary
Drive Fast....Brake Late....Take Chances
macspeedy
posted on 5/10/04 at 05:49 PM |
congratulations ![](/images//smilies/cool.gif)
pointy
posted on 5/10/04 at 06:30 PM |
spot on sir
I will be using Norwich (fingers crossed) april next year, and I must also say that I have popped in for advise during my build and they have always
been very helpful.
Andy p
James
posted on 6/10/04 at 11:48 AM |
Congratulations mate- well done!
Happy driving!
All the best,
James
splitrivet
posted on 6/10/04 at 01:08 PM |
Well done![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Bob
