Dooey99
| posted on 11/5/13 at 10:08 PM |
does the bulkhead have to be sealed?
for SVA does the engine compartment and bulkhead have to be sealed?
for instance do i have to have a rubber grommet or boot where the steering column goes through the scuttle?
i intend to put something there but wondered if it had to be done?
and what have people used to do this????
i was thinking something like this
eBay Item
Less weight more speed, more power more speed
If in doubt, give it a clout
loggyboy
| posted on 11/5/13 at 10:20 PM |
No it doesn't, as long as wiring/hoses etc that could be damaged when passing thru the bulkhead are suitably protected, nothing else does.
[Edited on 11-5-13 by loggyboy]
Mistral Motorsport
Dooey99
| posted on 11/5/13 at 10:23 PM |
Lovely Job, so just things that could be damaged have to be 'protected'
and off topic how many people put a support bearing on the steering column extension shaft?
Stott
| posted on 11/5/13 at 10:26 PM |
No it doesn't have to be sealed, mine wasn't completely sealed and it was fine. (on the robin hood)
The major requirement for bulkhead/compartment sealing is that the compartment containing the fuel tank must be sealed from the passenger compartment.
They are quite hot on this, even if your tank is in fron of you and there are no sides, bonnet or bodywork on the car, the little bit of aluminium
between the tank and your feet needs completely sealing to the chassis, ask me how I know...
[Edited on 11/5/13 by Stott]
Dooey99
| posted on 11/5/13 at 10:39 PM |
my fuel tank is mounted behind and above the rear axle... and all the fuel lines run through the prop tunnel
AdrianH
If you ever want top do MSA events such as sprints or Hill climb then yes, as well as lots of others!
But not for IVA Mine was not.
Adrian
[Edited on 11-5-13 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
Dooey99
| posted on 11/5/13 at 11:06 PM |
And can anyone suggest what gear stick gaiter/surround to use? I don't particularly like the black fake leather ones that droop and sag
everywhere
Daddylonglegs
| posted on 12/5/13 at 05:56 AM |
everywhere
Mine is the rubber one from a Sierra, looks like a little ribbed pyramid. I just cut a square hole in the tunnel cover and put the first
'ridge' of the gaiter under the panel and it sits in there fine so far.
Here's what I mean:
  Gear Lever
HTH
snapper
| posted on 12/5/13 at 06:07 AM |
What I would say is that in use any non sealed hole will force a jet of hot air into the cockpit
Sometimes with added oil or steam
I used expanding foam, sikaflex and adhesive silver tape as appropriate
Don't under estimate how hot the engine bay gets, the manifold also runs close to the footwell, I also used insulation mat inside the footwell
and heat reflecting stuff in the engine bay all over the bulkhead and part way down the tunnel
I eat to survive
I drink to forget
mark chandler
| posted on 12/5/13 at 07:36 AM |
everywhere
Cut down steering rack gator in mine, as above cut a hole for the inside of a rib and drop the first hoop through.
Regards Mark
| posted on 12/5/13 at 01:19 PM |
everywhere
MGB inner rubber one part number BHH2049 and also you can get the nice chrome ring to hold it on.
Do an ebay search on BHH2049
