J222jra
| posted on 13/5/13 at 05:48 PM |
Wilwood problem!!
Hi guys,
So I just received my wilwoods and have started fitting them, but I have a problem!!!
I've fitted the discs to my cortina hubs but the disc is catching the metal hub backing plate.
Has anyone else has this issue?
Thanks in advance
James
| posted on 13/5/13 at 06:43 PM |
If you mean the splash shield --- throw it away it is not required but I wouldn't expect the disc to be anywhere near it so assemble
it without the splash shield and check for rubbing contact anywhere else.
J222jra
| posted on 13/5/13 at 07:09 PM |
Is it because its vented discs?
I will follow your advice and check clearance without them fitted.
Thanks Britishtrident
