richyb
| posted on 10/10/04 at 08:58 PM |
cheap sierra brake parts - where !
i went to a local shop to get some overhaul kits for my sierra calipers the kit consists of a rubber dust shroud, and a rubber seal for the cylinder -
chap said £14 per set !! - i said no thanks !!
am i being silly or is he taking the P. would apreciate if anyone has any ideas for cheap sierra parts - i am also looking for a full set of discs
(4), and pads all round.
Mark Allanson
| posted on 10/10/04 at 09:19 PM |
Sounds silly, but it is the going rate, you should get a set of front discs for about £20, set of cooking pads for £10. Who told you this was going to
be cheap other than Uncle Ron?, £250 - who was he trying to kid?
richyb
| posted on 10/10/04 at 09:27 PM |
Just seemed like a lot of dosh for about an ounce of rubber ! - i might leave the old ones in as they werent leaking, and upgrade to some decent
callipers later in the day !!
thanks for the info though - am looking on e bay now for discs at about that price.
Chris_R
| posted on 10/10/04 at 10:35 PM |
You could try a Ford dealership. Once you've been there you'll prolly quite like to spend £28 at a motor factor.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
| posted on 10/10/04 at 11:07 PM |
Complete new calipers only £26+vat and seal kit £3.30+vat (or £7.13+vat including guide bushes) from http://www.brakesint.co.uk
Ben_Copeland
| posted on 11/10/04 at 08:10 AM |
Yep, mike beat me too it, would of recommended www.brakesint.co.uk
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
richyb
| posted on 11/10/04 at 07:28 PM |
thank you gents, i will check them out. - may even consider new callipers at that price. second thoughts no, i spent best part of the weekend
cleaning up the parts !!!
Mark Allanson
| posted on 11/10/04 at 08:30 PM |
Can they give the care to reconditioning that you can? My front calipers came from a cortina built in 1981, never touched in its lifetime, I stripped
them down and fitted a recon kit from GTS, but they probably never needed it. Hva a look first, all you can, loose is 1/2 an hour .
