Author: Subject: Quick milling job for beer tokens?
james h
posted on 10/6/13 at 06:22 PM Reply With Quote
I wanted to get this finished at uni but exams inconsiderately got in the way
Would anybody be able to do a quick milling job for some beer tokens?
I need to put two flats (15mm or slightly under wide), 180 degrees apart on the larger diameter section, then a 4mm tapped hole on each (I can tap the hole if its drilled to 3mm).
Ideally I would like another pass on a lathe to make a nice shiny finish, but that isn't crucial.
The material is fairly soft ali:
Column collar to be milled
If anyone could manage to do this for me, it would be very much appreciated - and beer tokens would be sent
tilly819
posted on 10/6/13 at 08:32 PM Reply With Quote
I can do that. You will have to post it down to me etc.
Tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
james h
posted on 11/6/13 at 12:48 PM Reply With Quote
Fantastic, thank you! You have u2u
