40inches
| posted on 12/6/13 at 11:07 AM |
Steering wheel QR???????
Any one used one of these? QUICK RELEASE 25mm NARROW SLIM STEERING WHEEL BOSS KIT HUB FITS MOMO HUB ADAPTER | eBay
Would fit nicely in place of this spacer.
Staple balls
| posted on 12/6/13 at 12:03 PM |
Single button release? Only £30? I wouldn't trust it to hold my trousers shut, let alone a steering wheel on.
Charlie_Zetec
| posted on 12/6/13 at 12:05 PM |
Do a search on here and have a read about horror stories from previous users of QR bosses. I've got two lockable ones (one on the kit, the
other on my Defender) that don't split without a key. Unfortunately they don't make them any more, but they do crop up on eBay once in a
blue moon....
renetom
| posted on 12/6/13 at 04:41 PM |
Hi
We used one of these
Its fine & very positive.
  wheel boss
  boss
Good luck
plentywahalla
| posted on 12/6/13 at 06:22 PM |
I've go one of those on my 7, although I haven't used it on the road yet.
It seems to be well designed and made and is good value. The small button is depressed and the outer ring rotated through about 60 degrees to unlock
the wheel. The wheel locates by three large lugs which seat in recesses in the hub. The locking ring has cut outs for the lugs to enter which then
close over to lock when the ring is rotated. The little pin is set to be upright between the spokes when locked so it is a visual check that all is
ok.
There is no slack, it is actually rather too tight and can be a bit of a struggle to engage, but i'm happy with it.
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
