T66
posted on 31/7/13 at 12:57 PM |
Silencer - Fuel tank Proximity ?
Intend to wrap the silencer, and also make a heat shield between the tank and pipe. Since the picture was taken Ive tweaked the pipes a bit more,
taking the silencer across to the n/s about 50mm.
The cardboard tank is an approximation, so can be made slightly smaller to increase separation from the heat.
verdict guys ? too close ? or ok ?
![](/galpreviews/) ![](/gallery/)
adithorp
posted on 31/7/13 at 01:42 PM |
Looks OK to me.
The risk of fire is negligible from heat (flames and sparks are another matter) so as long as the vent goes outside not a problem.
Heating the fuel will reduce performance though. I'd wrap the tank in good heat protection (that gold coloured stuff).
http://jpsc.org.uk/forum/
loggyboy
posted on 31/7/13 at 01:46 PM |
Wil the tail pipe bend rearward to terminate away from the tank?
Mistral Motorsport
T66
posted on 31/7/13 at 02:00 PM |
Like the tank wrap suggestion Adie - Consider it done.
Loggy - yes the tailpipe will be routed out under the o/s light cluster. ie Hole in shell.
Good feedback its appreciated.
edsco
posted on 31/7/13 at 02:35 PM |
If you are concerned, stick some heat reflective mat/sheet to the tank.
edsco
T66
posted on 31/7/13 at 03:27 PM |
Noted thank you....
