Author: Subject: Ford type 2 rear oil seal
puma931
posted on 19/9/13 at 09:12 AM Reply With Quote
Would this puller be OK to remove the rear oil seal TOOLMATE US Bearing puller 3” 75mm Triple Leg Reversible Gear Hub puller
I tried hammer and screw driver on my knackered old box, but could not get it out. Will the puller in the link above fit, or is it too big??
[Edited on 19/9/13 by puma931]
Trollyjack
posted on 19/9/13 at 04:05 PM Reply With Quote
It should come out easy just collapse the seal with a hammer and screwdriver
TrollyJack
posted on 19/9/13 at 04:11 PM Reply With Quote
As above no special tool needed
[I] What use our work, Bennet, if we cannot care for those we love? .
puma931
posted on 19/9/13 at 08:41 PM Reply With Quote
Managed to get it out using a hammer and chisel. it did take some bashing before it came out!!
hypersonic
posted on 22/9/13 at 07:16 PM Reply With Quote
I drilled a small hole in mine then wound a self tapper in and used a set of mole grips to pull it out.
