gaz05
posted on 11/10/13 at 01:23 PM |
Rack position
Spent the last two hours reading all the search results and it's still as clear as mud
I'm building a Haynes and am assembling the front sus and steering. Sierra uprights,Escort MK11 rack,Protech shocks and everything to book.
First thing I've noticed is quite a bit of bump steer. I've got the bottom bone horizontal which I think is about the position it will be
when on the ground. With a 12" rule clamped to the disc, when I jack it up about 50mm the rule moves out of straight about 20mm. I'm
guessing this is too much and given that the rack is on it's highest position on the bracket it looks like I'm going to have to rip it out
and fab up a new bracket.
My intention is to make the rack sit about 15mm higher and be adjustable fore and aft so I can experiment with a bit ackerman later on when the cars
on the road. The rack already sits about 40mm behind the centre line of the TREs so will probably make that the centre point of the adjustment.
You can see the rack isn't in the best position. I know many variables come into play with suspension set ups. Is my plan a viable option?
Daddylonglegs
posted on 11/10/13 at 01:36 PM |
Not much help with your question I'm afraid, but all I can say is that the ride is going to be 'interesting' without springs!
But I had a nightmare trying to get rid of the bump-steer on my Locost. I've got it to a minimum but it's still got some.
[Edited on 11/10/13 by Daddylonglegs]
posted on 11/10/13 at 03:26 PM |
There is another option fit rose joints to the outer track rod ends which will allow yo to adjust the vertical height of the outer.
Looking at your picture I would also think you need longer track rod extension before IVA.
mark chandler
posted on 11/10/13 at 04:19 PM |
Pull back the gaiter on the rack, when you view from the front you should be able to draw a straight line through the centre of the knuckle on the
rack and both bone pivot points, this sets your height, extend with something temporary to determine the best position then build the final solution
in the optimum place.
gaz05
posted on 11/10/13 at 05:53 PM |
They have 20mm entered each side. Should be enough. They could have been a bit longer though. The other stuff I got from 3GE needed work also.
Dusty
posted on 11/10/13 at 10:30 PM |
Can you post a longer range pic to show relative positions of the wishbones. That pic suggests they are close to parallel remembering that
mechanically the wishbone is a line between the centre of the ball joint and the inner bush. Rack seems too low but difficult to tell from the pic you
have posted.
posted on 12/10/13 at 08:38 AM |
Do you have offset mushrooms ?
Setting offset mushrooms with the ball joint hole to the rear will lower the steering arms which has (almost) the same effect as raising the rack.
