madteg
posted on 21/10/13 at 07:52 PM |
Brake problem on track
I have a good pedal most of the time but when brakes are hot on track, the pedal goes down about 2" and then its hard again. This is a little
unnerving, Have tried different types of fluid. When brakes have cooled down the pedal comes back to normal.
NigeEss
posted on 21/10/13 at 08:02 PM |
Sounds like brake fade.
What pads are you using ?
Bare
posted on 21/10/13 at 08:04 PM |
Gas from boiling fluid (water usually) is compressing... Flush and refill the Brake fluid BEFORE Each race.
madteg
posted on 21/10/13 at 08:09 PM |
Running big discs (297mm) with 4 pot Brembo calipers, ferodo pads
yellowcab
posted on 21/10/13 at 08:17 PM |
What pads exactly? ds2500 are only really a fast road pad, very entry level track day
Anything more full on than that, you'd want ds3000 compound or higher to eliminate any fade
snapper
posted on 21/10/13 at 08:23 PM |
Brake fade does not give a dropping pedal
I go with Bare's view
Brake fade gives firm pedal but with much less slowing
Dropping pedal different problem
I eat to survive
I drink to forget
madteg
posted on 21/10/13 at 08:27 PM |
Will try new fluid and get some hot pads, thanks guys. Kev.
posted on 21/10/13 at 08:50 PM |
First thing it is fairly safe to say it isn't pad material related.
It isn't brake fade, brake fade is an increase the pedal effort needed to slow the car due to the friction coefficient of the brake changing
with temperature. With brake fade the pedal travel doesnt change but the push required on the pedal increases progressively tup o a point where the
pad friction coefficient falls off a cliff.
Long pedal when the brakes are hot is either caused by fluid boiling or if you have drums on the rear the drums expanding.
Fluid boiling causes a very sudden increase of pedal travel.
With drum expansion the increase in travel is less sudden.
Brakes have to get very very hot for fresh brake fluid to boil, with fluid boiling normally the first thing to look for is a binding brake. Check
the brake temperature on each wheel. If the brake fluid reservoir is overfilled it can cause over heating, also check the brake pedal has a return
spring. Jacking out the master cylinder pus rods often leads to problems, the master cylinder piston must always come fully back against the
end stop of the cylinder.
Calliper or handbrake problems are often the cause of binding brakes, check the pistons and pads are moving freely in the calliper and with Sierra
floating callipers check the callipers is moving freely on the guide pins and the handbrake cable has enough free.
If a calliper appears to be seized partly binding with no other cause the problem can be caused by the inner rubber seal hardening.
[I] What use our work, Bennet, if we cannot care for those we love? .
unijacko67
posted on 21/10/13 at 09:13 PM |
When you say the pedal is soft then hard again do you mean it comes hard after one pump or when its cooled down as a slack wheel bearing or slightly
warped disk will rattle the pads back into the calliper so the first pump is pumping the pads to the disc, second pump and it will work.
http://www.kittenkitcar.co.uk
madteg
posted on 21/10/13 at 09:23 PM |
After 1/2" of travel the pedal is hard. When brakes are hot on track the pedal travels about 2" then i have a hard pedal. The same
pressure is needed to stop the can.
unijacko67
posted on 21/10/13 at 09:32 PM |
Sorry ignore my ramblings in that case.
CNHSS1
posted on 21/10/13 at 09:36 PM |
Pad knock off under hard cornering? Not present under normal driving but when leant on, wear/slop/poorly adjusted bearings allow small amount of disc
movemnet oushing pads back giving a longer pedal until the extra piston movements taken up?
On some classics used to circuit race, can even be stub axle flex
madteg
posted on 21/10/13 at 09:40 PM |
Now this could be it i like it. Thanks.
ashg
posted on 21/10/13 at 11:11 PM |
I'm guessing your master cylinder is not the highest point in your brake system. If that is the case then you need one of these on each
line.
http://www.rallydesign.co.uk/product_info.php?cPath=562_596&products_id=4081
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 22/10/13 at 06:23 AM |
line.
The height of the free surface of the fluid in the reservoir rather than the height of the master cylinder is what matters even then the
effect is tiny when the car is being driven.
posted on 22/10/13 at 06:34 AM |
Pad knock back used to be common on the old Formula Fords and similar formula but unlikely with modern wheel bearings and floating
callipers as used on Sierra it is much less likely unless something is wrong such as a really knackered wheel bearing or a warped disc.
One measure to counter pad knock back is fitting a residual pressure valve as mention by ashg another is fitting very light light springs inside
the callipers, both of these cures are really last ditch measures.
eddie99
posted on 22/10/13 at 07:27 AM |
Id say brake fluid, symptoms don't lead to a pad problem
It's mega expensive but if you can try the castrol srf, IMO it's the best fluid and will eliminate a fluid problem
We were having to flush through regularly using the willwood high temp stuff, the castrol Is another league
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
