Author: Subject: Bedding in Brakes - how much?
davidimurray
posted on 29/10/13 at 02:03 PM Reply With Quote
One think I would like to do before my IVA is to get the brakes bedded in. New rear shoes and front pads, nothing special just some generic ones.
I only live about a mile from the IVA test centre so I can take a bit of a scenic route but anything too extreme could be considered taking the p** by the old bill.
So how much driving do you need to do to get the brakes bedded in and what is the best way of doing it. Can get a few laps round the backstreets around the house but hitting 30mph would be pushing it. Is it best to drag the brakes or try and put some big heavy stops on it?
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Davey D
posted on 29/10/13 at 02:44 PM Reply With Quote
With my latest pads, i found the only way i could get them bedded in quickly was on a trackday. Because these cars are so light, stop so easily, and going steady this time of the year on the roads, i just couldnt bed them in well enough
loggyboy
posted on 29/10/13 at 02:53 PM Reply With Quote
Brand new pads and discs wont take as long as used discs and new pads, However, considering IVA braking is done at such low speeds I cant see them not being bedded in completely being an issue. If you take a scenic route to the acctual IVA making sure you do lots of gentle braking on the way, that should be fine.
Mistral Motorsport
davidimurray
posted on 29/10/13 at 02:55 PM Reply With Quote
I've got used discs and new pads
loggyboy
posted on 29/10/13 at 02:58 PM Reply With Quote
Buy new discs? Not much more than about £10 each.
Or just take a even more convoluted route to IVA!
[Edited on 29-10-13 by loggyboy]
Mistral Motorsport
RickRick
posted on 29/10/13 at 03:17 PM Reply With Quote
take the shortest route to the IVA, but forget things, lots and lots of times!
davidimurray
posted on 29/10/13 at 03:33 PM Reply With Quote
Do new discs make that much of a difference?
40inches
posted on 29/10/13 at 03:37 PM Reply With Quote
You need a full tank of petrol, find the "nearest" petrol station
posted on 29/10/13 at 05:11 PM Reply With Quote
That depends on whether your old discs look like mine tend to, like a cross section of the Highlands. I swear my ears must be bad as I never notice any grinding, but my discs are always mullered.
loggyboy
posted on 29/10/13 at 05:25 PM Reply With Quote
Exactly, its all about getting the surface of the pad to merge with that of the disc. If they both start perfectly flat its alot quicker. A big fat lip on the edge and lots of ripples mean not only will it take longer to bed in, theres more chance of the pad glazing.
Mistral Motorsport
