Author: Subject: FS - Fuel sender for standard MK tank
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 4/12/13 at 07:02 PM Reply With Quote
I have changed to a much larger tank and as such no longer need my old fuel sender.
I have popped it on eBay!
These are a million times better than the lever arms ones as they give a very accurate and steady reading. The bolt pattern and wiring are a straight swap for a standard sender.
Please note the ohm range in the listing.
For my new tank I have bought the exact same one but longer (I also have a longer one for sale in my otter items that is a different ohm range!
CLICK
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 5/12/13 at 06:23 PM Reply With Quote
Thanks for the views! fingers crossed someone wants it!
Cheap as chips at £9,99, an easy upgrade over winter!!
