minibeezo
posted on 15/12/13 at 09:06 PM |
7.5" lsd in a scorpio
Hi guys. In need of some expertise, im looking to put a lsd in my scorpio car. What 7.5 inch lsd can i use to make this possible?
melly-g
posted on 15/12/13 at 10:38 PM |
Which Scorpio do you have?
Early ones have an lsd I believe!
minibeezo
posted on 15/12/13 at 10:44 PM |
It's the frog eye shape and no they only came with traction control just not my model
snapper
posted on 16/12/13 at 06:44 AM |
Any 7 ½ from Sierra cossy will do
Most were 3.64
I eat to survive
I drink to forget
minibeezo
posted on 16/12/13 at 07:03 AM |
Will the drive shafts from my scorpio be the same or do I need shafts aswell
mcerd1
posted on 16/12/13 at 09:38 AM |
the sierra cossie 2wd has a 7.5" LSD with 108mm CV joints
your one has 100mm CV joints
ford LSD's use different flanges/stub axles in the diff - they are unequal lengths (your current ones are equal length in the open diff)
the only strait swap is for the earlier granada cossie one - otherwise you'll need to make a 7" LSD fit or change to the sierra cossie
108mm shafts and hubs
[Edited on 16/12/2013 by mcerd1]
minibeezo
posted on 16/12/13 at 09:42 AM |
Would the internals from the sierra cossie diff fit inside the Scorpio casing?
mcerd1
posted on 16/12/13 at 10:05 AM |
^^^ that doesn't save you anything - as I fairly sure the casings are basically the same - its the stub axles/ flanges on the diff that are
the issue
...well your one might have the other type of rear mount, but you only need to swap over the rear covers to sort that
PAUL FISHER
posted on 16/12/13 at 11:04 AM |
The early Ford Scopio's ran a 7.5" 3.36 ratio LSD, the same as what is fitted to my Westfield Seight
