Hopley89
| posted on 20/12/13 at 01:53 PM |
Brake master
Hi
I'm about to order my brake master cylinders but I'm unsure if they have got
To be tandem or single for Iva .. I now they have to be clear for Iva .?
So could do with some help before I order
Thanks dan
Hopley89
| posted on 20/12/13 at 01:59 PM |
I will be using a bias bar as well
| posted on 20/12/13 at 02:41 PM |
If you don't have a detailed knowledge of setting up braking systems then perhaps using a bias bar is not a good idea, they are best use for
serious track use only, it is too easy to get temptned into twiddling with the brake balance !which can result in spinning into a hedge when you
least expect it.
I would suggest instead you fit a single tandem cylinder. Loads of info in the threads on Fiat or early Fiesta master cylinders.
However if you really want a bias bar set up you need single circuit cylinders, I would suggest a starting with a 0.625" cylinder on the front
and a 0.7" cylinder on the rear circuit.
[Edited on 20/12/13 by britishtrident]
Hector.Brocklebank
| posted on 20/12/13 at 03:29 PM |
least expect it.
+1
Thats a sound bit of advice deviate at your peril.....
Some people can never handle the truth and always try to shoot the messenger instead of taking an honest look in the mirror (its always easier to
blame another than to face reality), but secretly they wish they could grow a pair and be the messenger !!!
theprisioner
| posted on 20/12/13 at 04:06 PM |
The J15 it has a bias bar, I have it set up road tested and wire locked. The J15 pedal box as supplied cannot accommodate a tandem cylinder otherwise
I would have fitted one (no room). My Megabusa has one and it came locked in place. I had labels made up that reflect the IVA law must fit one to the
Westie!
  Warning
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
Hopley89
| posted on 20/12/13 at 04:14 PM |
I now how to set up all the braking .. I've done most of it already but I've never set up a bias bar .. So I would of taken it the garage
to get done
So bias bar I can have a single
No bias bar have a tandem
Dan
| posted on 20/12/13 at 04:33 PM |
to get done
Dan
Garages wouldn't know how to setup balance bars.
theprisioner
| posted on 20/12/13 at 05:10 PM |
In my opinion you need to make up a temporary jig, to operate the foot brake, to finely tune the bias bar before taking it on the road. The road is
the last place to adjust it.
Hopley89
| posted on 20/12/13 at 05:50 PM |
I'm going to stick without the bias bar for now .. And
Find someone who nows how to set it up correct for me
As I don't want to mess it up and end up In a hedge
... Thanks tho chaps
