Xtreme Kermit
posted on 20/1/14 at 06:41 PM |
Hubcentric spacers. Thoughts?
I need to space my rear wheels out to fit the tub a bit better.
I was thinking 25mm with both on hubcentric spacers.
Good idea/Bad idea?
40inches
posted on 20/1/14 at 06:59 PM |
I would go with hubcentric and longer studs, shouldn't be a problem.
TimC
posted on 20/1/14 at 08:10 PM |
I once bought some Eibach hubcentric spacers - costly but very nicely engineered.
Xtreme Kermit
posted on 20/1/14 at 08:20 PM |
I was trying to be lazy a avoid replacing the studs...
loggyboy
posted on 20/1/14 at 10:42 PM |
25mm is on the limit of needing Bolt on hubcentrics, IMO they are better than pass thru hubcentrics with longer bolts, but a fair amount dearer. 20mm
would be ok with entended bolts and JJC do a pair with bolts for about £30
Mistral Motorsport
rodgling
posted on 20/1/14 at 11:25 PM |
I have 25mm bolt on hubcentric spacers for this reason, works great. Although I have killed a wheel bearing in a pretty short time period, perhaps due
to the extra load.
mcerd1
posted on 21/1/14 at 08:49 AM |
dearer
yet I'm pretty sure its the bolt-on hubcentrics that are banned from several race classes due to safety issues...
long studs are the best solution
loggyboy
posted on 21/1/14 at 10:18 AM |
dearer
Basic MSA regs ban extended studs:
5.8.2. Not be fitted with any wheel spacer exceeding 2.5cm in thickness or of less than hub diameter. Multiple or Laminated Spacers and extended
studs are prohibited.
Mistral Motorsport
Xtreme Kermit
posted on 21/1/14 at 01:49 PM |
maybe I should back off to 20mm and fit longer studs in that case.
20mm should be enough to alter the appearance, soI guess I had better pull those hubs off and take 'em to a press!
loggyboy
posted on 21/1/14 at 01:56 PM |
Are you attached to your wheels? Replacements with lower offset would have the same effect.
Mistral Motorsport
Xtreme Kermit
posted on 21/1/14 at 05:16 PM |
mmm - now there's a thought... I always fancies a set of Team Dynamics 1.2s...
Cost is against me there though
