Author: Subject: MX5 IRS
cb500t
posted on 20/1/14 at 07:03 PM Reply With Quote
MX5 IRS
Is anyone producing rear wishbones to fit the MX rear IRS to a Champion chassis,I just fancy going from live rear end to IRS especially as I have a whole MX as a donor?
Talon Motorsport
posted on 21/1/14 at 06:53 AM Reply With Quote
I think you would need some sort of rear cage/box structure to mount the wishbones to, if your going for a home brew of mix and match parts start at the uprights buy a cheap set of wishbones then build the suspension cage to suit. If you try and do it the other way round you'll end up having to buy/make custom wishbones. There's also the small matter of how to mount the mx5 diff.
cb500t
posted on 21/1/14 at 01:49 PM Reply With Quote
The revised rear structure is taken care of....I intend using the top wishbones that cane with the subframe,and I ' just ! ' need bottom wishbones.
