Author: Subject: odd alloy wedge shims on sierra hub?
baz-R
posted on 21/2/14 at 05:23 PM Reply With Quote
i got some used sierra xr4x4i rear end bits and bobs the other day and on both of my rear hubs there is an alloy wedge shape shim or spacer stuck on the back anyone know what thay are?
the guy was local ish and had a pritty tooled up xr that was killed by tin worm come the end. he had all sorts of fancy bits and bobs for sale so im thinking thease are non std.
CNHSS1
posted on 21/2/14 at 05:30 PM Reply With Quote
caterham did some tapered shims to alter toe on the dedion axle which used ford hubs iirc
http://www.dpr-motorsport.com/accessories/caterham_shims.html
baz-R
posted on 21/2/14 at 05:38 PM Reply With Quote
nope that not it
its like a laser cut bit of alloy plate cut to fit and the milled at a slight angle
looks like alot for tracking or toe so im thinking it is to ajust or correct cambre.
dave r
posted on 21/2/14 at 05:41 PM Reply With Quote
if they are what i have, then they correct toe and camber, when you run the suspension lower than uncle henry intended
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
robinj66
They're commonly called "camber shims" - aftermarkets bits to reduce rear camber on Sierra donor items.
Both RHOCaR (Robin Hood Owners Club) & FSOC (Sierra Owners Club) members have them for sale
HTH
baz-R
posted on 21/2/14 at 06:15 PM Reply With Quote
ah so might be useful to someone here then?
dave r
posted on 21/2/14 at 06:38 PM Reply With Quote
anyone with a sierra rear beam....
they make a lot of diffence
theduck
posted on 21/2/14 at 08:27 PM Reply With Quote
Yep sound like camber shims. About £30 new.
CosKev3
posted on 21/2/14 at 09:01 PM Reply With Quote
Do they really make a big difference on a light kit car?
On a lardy Sierra they do,as when you boot them the diff/shell squats and pulls the rear wheels into massive camber.
Take a look at a Cosworth launching from behind!
dave r
posted on 21/2/14 at 09:11 PM Reply With Quote
they do when the rear end is already running a couple of inches or so lower than it should in the sierra......
its in permanent squat
