chicade
| posted on 22/2/14 at 11:12 PM |
Geometetry settings Mk indy
I know there is lots of different options regarding settings but I am after a good starting point for fast road n track day use it's a old Mk
indy and after a few winter mids is now sat on 13's and a048's rose jointed front wishbones I have set the ride height and am happy with
the ride shockers are set 6 clicks from 0 what do you recommend toe in/out caster camber? Front n rear?
[Edited on 23/2/14 by chicade]
Matt21
| posted on 11/3/14 at 07:54 PM |
on the mk website there is a manual for the build, near the end is the recommended base set up then you can fine tune from there
| posted on 11/3/14 at 08:22 PM |
Toe should be parallel to a tiny amount of toe-in. on the front say. 0 to 0.125. essentially you want to as close to parallel as possible but avoiding
toe-out.
At the rear a bit more toe-in aim for say 0.125. again avoid toe-out. at all cost, toe-out on the rear can be nasty.
Camber really depends on what use you put the car more negative camber on the front gives better turn in and less under steer at the expensive ofbtyre
wear.
Try 1 degree negative all round.
Camber should be set before toe-in
whitestu
| posted on 11/3/14 at 08:48 PM |
Rear toe is fixed on the Indy unless you start shimming. Mine reads as 1.5 degrees.
I have 1 degree of toe at the front, 1 degree neg camber and 6.5 degrees of caster.
Stu
yellowcab
| posted on 11/3/14 at 09:11 PM |
I have rosejointed rears so they're adjustable too
Front:
-2.0 negative camber
1.4mm toe in @ rims
4.5 degrees of castor
Rear:
-1.0 negative camber
2mm toe in @ rims
Thrust alignment taken from chassis
