Author: Subject: 17inch alloys?
Razzakit
posted on 15/3/14 at 04:20 PM Reply With Quote
17inch alloys?
Basically ive got a spare set of 17" alloys, will they fit okay on my Haynes style locost in building or are 17's a bit on the big side?
Wadders
posted on 15/3/14 at 04:29 PM Reply With Quote
depends if you want it to look good, or go round corners quick
fesycresy
posted on 15/3/14 at 05:09 PM Reply With Quote
4" too big
Davey D
posted on 15/3/14 at 06:21 PM Reply With Quote
Don't do it!
Stick to 15" or 13" if you want decent tyre choice, or 14" if you want something in between albeit with less tyre choice
Razzakit
posted on 15/3/14 at 06:25 PM Reply With Quote
Thought that might be the case, ill stick them wheels on my civic then haha. I suppose i could then use my civic 15" wheels as they are a 4x100 fitment and in guessing if i use either the ford ir mazda hubs they should fit fine.
Davey D
posted on 15/3/14 at 07:06 PM Reply With Quote
Ford is 4x108 so unfortunately you won't be able to use the wheels unless they are double fitment drilled
davidimurray
posted on 15/3/14 at 10:02 PM Reply With Quote
Assuming book rear uprights then the smallest you can go is 15"
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
