BigDawgV8
| posted on 18/3/14 at 09:08 PM |
Best brake Master Cylinder?
Hi All,
I'm in the process of replacing the master cylinder on one of the Morris.
The brakes are standard Sierra discs and calipers all round.
It previously had a Fiat 126 master on there.
I'm tempted to go for the slightly bigger Fiat Panda master, as suggested elsewhere on here, but are there any other types of master cylinder
to consider?
Thanks for reading!
adithorp
| posted on 18/3/14 at 09:16 PM |
Going bigger bore will increase the amount of force required at the pedal. Guess the decition depends on how you find the braking now.
http://jpsc.org.uk/forum/
rdodger
| posted on 18/3/14 at 10:53 PM |
I went from Fiat 126 (3/4" to Nissan Stanza which is 13/16"
If you want a firmer pedal there is I believe a 13/16" Fiat 126 mc available which would make life easier. I wish I had known before I swopped!
