liam.mccaffrey
| posted on 26/3/14 at 04:40 PM |
Balljoint Engagement
I now know that the maxi ball joint fits my mgzr uprights, however the engagement of the taper is only about 2/3rds.
Personally I don't have a problem with that, just looking for others opinions?
Build Blog
Build Photo Album
big-vee-twin
| posted on 26/3/14 at 05:32 PM |
Full nyloc nut and washer on with a couple of threads showing is my measure.
http://www.triangleltd.com
| posted on 26/3/14 at 06:48 PM |
I would want a bit more, generally ball joints show more thread than a normal but and bolt.
I assume is to give a bit more of a margin in case the but starts to slacken.
liam.mccaffrey
| posted on 26/3/14 at 06:58 PM |
Sorry I should clarify, I have full nyloc engagement with threads showing. Its just the female taper isn't sat right at the base of the male
taper.
Ill take a picture. later
Build Blog
Build Photo Album
steve m
| posted on 26/3/14 at 07:15 PM |
Liam
If i m reading right, could you not ream out the "ole" to allow a better fit?
liam.mccaffrey
| posted on 26/3/14 at 10:25 PM |
Yes Steve I could,
I'd need to find the correct reamer though. I'm not sure if the trusty axminster one for the transit drag link is the same taper as the
bottom maxi balljoint... anyone know?
Build Blog
Build Photo Album
