Author: Subject: Ford type 9 gearbox
ZEN
posted on 6/11/04 at 07:18 PM Reply With Quote
Ford type 9 gearbox
Is this gearbox only fited to Sierras? What year/model? Are al the type 9 boxes with the same gear ratios?
My YouTube channel Cars, bikes - track days, motorsport, sim racing and more.
stevebubs
posted on 6/11/04 at 08:30 PM Reply With Quote
Type 9
Sierras and Capri Lasers (Laser models were 5 speed)
Capri 2.8 models had a longer input shaft which needs either grinding down or a thicker spacer plate between engine and gearbox. However, the 2.8 gearboxes also had better ratios for seven-style cars
ZEN
posted on 6/11/04 at 09:52 PM Reply With Quote
What years Sierras?
Mark Allanson
posted on 6/11/04 at 09:53 PM Reply With Quote
82-89, some transits had them too
stevebubs
posted on 7/11/04 at 02:34 AM Reply With Quote
I think the transits had the gearshift in a different position (much closer to the bellhousing)
stevebubs
posted on 7/11/04 at 02:36 AM Reply With Quote
Easy way to check which gearbox a Sierra has is the position of reverse -
If it's below 5th (bottom right) then it's an MT75
If it's to the left of first (top left) then it's a Type 9
posted on 7/11/04 at 09:02 AM Reply With Quote
Granadas used them as well.
ZEN
posted on 7/11/04 at 12:27 PM Reply With Quote
This is a good tip
stephen_gusterson
posted on 7/11/04 at 11:55 PM Reply With Quote
also, if its got a DOHC engine, it wont have a type nine. DOHC have MT75
atb
steve
