daveb666
posted on 8/4/14 at 11:18 AM |
Cortina Upright Front Brakes
Rather ashamed to post this but ..
I'm going to replace the front discs and pads on my locost but from a quick flick through a few websites it seems I've got to mess about
with bearings etc to replace the discs.
Is this correct? I have a bad history with bearings on cars (we won't go there in this post) LOL so I'm loathe to dismantle and
potentially break something that currently works.
Any advice?
big-vee-twin
posted on 8/4/14 at 11:34 AM |
The disc is bolted to the rear of the hub, so you have to take off the hub to remove the disc.
However the bearings are taper bearings and are only tightened up to something like 25NM take out the split pin loosen the nut and they will come off.
No big hammer needed.
http://www.triangleltd.com
big_wasa
posted on 8/4/14 at 11:59 AM |
quote: Originally posted by daveb666
Any advice?
Yeh man up
Davey D
posted on 8/4/14 at 12:00 PM |
It is a very easy job to do. Ive had one that has been a bit tight to get off, but with a hub puller it was no problem
