gregf27
| posted on 9/4/14 at 06:25 PM |
Ford brake master cylinder reservoir ID required!!
Just had my old ford brake master cylinder completely overhauled ( which has now been re- sleeved with a stainless steel tube which prevents it from
corrosion ) . Company called Past Parts ltd in Suffolk who advertise in practical classics mag.
Tried fitting the plastic reservoir , (which I'm unsure what model it came from!) thing is - its split when pushing it onto the master
cylinder and need another -does anyone on here have a spare I could have?
Pic below is what it is
its holes on the base are 85mm apart , length 125mm, width 60mm, part number 2274470149 Girling
many thanks for your help
Greg
SteveWalker
| posted on 9/4/14 at 08:01 PM |
I'll have to check in the garage, but I'm pretty sure I've got one around - it's a squarer version, but the connections are
probably the same and the thread for the cap/switch will be.
gregf27
| posted on 9/4/14 at 08:21 PM |
Many thanks Steve,
greatly appreciated
SteveWalker
| posted on 9/4/14 at 09:26 PM |
I've just been out there and I must apologise, it seems to have disappeared - if you saw my garage you'd understand. I'll have
another look tomorrow evening, but there's a chance it's been thrown out in my futile attempts to clear up.
gregf27
| posted on 11/4/14 at 11:14 AM |
Thanks for looking Steve, does anyone else have one at all? Or can recommend a remote set up?
Cheers and beers , Greg
melly-g
| posted on 14/4/14 at 05:36 PM |
I have a brand new one sitting in my garage.
gregf27
| posted on 14/4/14 at 06:20 PM |
Melly-g you have u2u
