Niels
| posted on 16/4/14 at 12:51 PM |
Do these brakes fit the sierra hubs or need to be turned down?
I'm at the stage of ordering my brakes and have already got a lot of information and suggestions but just to be sure.
Is it possible to fit these on my MK indy sierra rear and front hubs? Or should they be turned down to 134mm? I already have some disc uprights for
the rear.
And could someone tell me the outside radius "E radius" of the braking system with these 260mm discs. I'm only able to find the
273,1mm and up sizes for the midilites while rally design offers them with 260mm discs. As I want to be able to fit 13" wheels on them.
http://www.rallydesign.co.uk/product_info.php?products_id=14504
Thanks in advance
Niels
mcerd1
| posted on 16/4/14 at 01:19 PM |
I'm pretty sure the ones in the rally design link are being sold as a front brake set only
the 260x24mm vented discs in that kit are consistent with the standard sierra brake disc's for cars with ABS and the XR4i etc... check with
them first but I be they are just the standard sierra discs (or drilled / grooved versions of the standard ones)
on the sierra you would normally have a 253mm solid disc on the rear with smaller calipers
but these are far more powerful that is really needed for a lightweight car - in cact rally design sell a front brake kit for sierra donor based cars
using a solid 257mm disc to save weight
Ben_Copeland
| posted on 16/4/14 at 02:03 PM |
You'd be better off with the PowerLite kit, depending on your application.
That is a front kit, you definitely don't need vented midlites on the rear
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
