AntonUK
| posted on 18/4/14 at 05:17 PM |
Fitting a Crownwheel to the Diff?
I'm in the process of swapping the crown wheel on my LSD.
Does anyone have any tips/tricks to pushing the crown wheel over the diff its seems excessively tight.
Removal was difficult but eventually managed it with a vice, wooden block and a hammer.
Its an english axel.
Help?
Build Photos Here
baz-R
| posted on 18/4/14 at 06:34 PM |
cold diff hot crown wheel 100deg and a copper face mallet if it doesnt drop down by its self
if its nice and clean and the wife is out you could put it in the oven.
if you have ever fitted a bearing race hot you never bother with all the bashing ever again
AntonUK
| posted on 18/4/14 at 06:47 PM |
its done... finally.... used a puller and lots of heat to get it so far, then its was close and free enough to use the fixing bolts to pull it the
last 2mm... pheww..
Build Photos Here
snapper
| posted on 18/4/14 at 07:49 PM |
I'm sure you need matching pinion
I eat to survive
I drink to forget
AntonUK
| posted on 18/4/14 at 09:57 PM |
You do... and I have
Build Photos Here
| posted on 19/4/14 at 11:08 AM |
last 2mm... pheww..
Depends what you mean by lots of heat, an oven is OK but blow lamp is likely to ruin the heat treatment.
