liam.mccaffrey
| posted on 28/4/14 at 11:46 AM |
I machined a shiny bit....and it works
After much faffing I decided to bite the bullet and make this part myself. After much carefull setting up of the top slide with DTI, I machined this
beauty. I was really worried about the matching taper but it turned out perfect. Initial fit showed good contact with machinist blue. When I bolted
it up proper I actually struggled to seperate the parts which I'm taking as a good sign.
Its essentially converting my MGZR front upright to take a balljoint, like the sierra mushroom adapters but bigger.
I am a little pleased with myself.
  Adapter
[Edited on 28/4/14 by liam.mccaffrey]
Build Blog
Build Photo Album
HowardB
| posted on 28/4/14 at 12:41 PM |
I made this,... not sure if it works, but it was great fun,.
  hose_sensor
hose with water temperature sensor housing
[Edited on 28/4/14 by HowardB]
Howard
tegwin
| posted on 28/4/14 at 01:06 PM |
  hose_sensor
Is that machined from solid!? Possibly the most expensive temperature housing ever :p Looks cool though.
www.verticalhorizonsmedia.tv
HowardB
| posted on 28/4/14 at 01:08 PM |
na,.... it was a tube, and a collar heat shrink fitted,. -20 and +250C,.. then finished,..
Solid would have been more swarf than I have space for,.
Howard
