peter030371
| posted on 1/5/14 at 10:50 AM |
Fitting a ball joint
OK am I missing some clever trick.....
I managed to borrow a 42mm deep socket and have fitted my ball joints to my modified sierra front uprights on the Striker. Next stage is to bolt these
to the bottom wishbone and then the top rocker arm. How do i stop the ball joint from spinning around as i put the lock nut on?
I have tried squeezing the rocker onto the ball joint with a large g-clamp so the taper gets a chance to 'bite' but still just as the nut
starts to tighten the ball joint just spins around and around
Managed to get 2 of the four done but the last two are driving me up the wall
So whats the trick I am missing?
adithorp
| posted on 1/5/14 at 11:08 AM |
It happens sometimes.
Pressing the jont into the tapper is the usual method but occationally isn't enough. Either an air gun will have enough impetus to do it.
Alternativly screw your "new" locknut onto a bolt first to cut a thread in the nylon and then try on the joint... or take one of your
other joint nuts off and screw your "new" locknut down onto that one and use the "used" one on your new/loose joint. Having
already been on once it should screw on easier but it'll still be OK to lock it.
http://jpsc.org.uk/forum/
peter030371
| posted on 1/5/14 at 11:27 AM |
I've tried all that and one is still spinning
I got a normal nut of the correct thread to try and pull the taper up tight first......now I can't get that nut off as the joint is just
spinning
Why is it the simple things like fitting 4 nuts takes several hours of faffing about
Any other suggestion before I give up for the day and do something else instead (like sit in the corner crying )?
Davedew
| posted on 1/5/14 at 12:14 PM |
I used a small ratchet strap around the top and bottom wishbones to pull the joints into the upright. Surprising how much force you can apply to the
joints with even a small strap.
43655
| posted on 1/5/14 at 12:23 PM |
Not sure what it is exactpy, but could you slit the top of the thread and use a screwdriver to stop the taper bit turning? Think I just used an air
gun thing last time
liam.mccaffrey
| posted on 1/5/14 at 12:47 PM |
I wound on a plan nut to seat the joint before putting the nylock on
Build Blog
Build Photo Album
peter030371
| posted on 1/5/14 at 01:03 PM |
Lots of good suggestions
I will try the ratchet strap first....as soon as I have found my ratchet straps and then the slit top is the last resort.
Why don't they make these with an Allen key insert in the top so I can hold it with a key and use a spanner to do it up?
adithorp
| posted on 1/5/14 at 01:32 PM |
If you do that putting a socket/tube over the threaded end and use that the tap the wishbone/rocker down onto the tapper can help seat it... hitting
it with a big hammer will make you feel better even if it doesn't help fix it!
Wipe any grease/oil from the tapper will also help it grip. Ratchet strap around it, jack underneath, bar and scaffold pipe with the Mrs sat on the
end...or a combination of all...
peter030371
| posted on 1/5/14 at 02:17 PM |
I've cleaned the taper with IPA, used the Mrs (!), put a socket over it and clamped it up with a g-clamp really really f'ing tight (bent
the threaded part of eh g-clamp and it was no light weight clamp) but its still one of the 4 joints slips.
Found my ratchet straps, at least that way I can keep the load on whilst doing it up. Run out of time today but will try again in the next few days
40inches
| posted on 1/5/14 at 02:25 PM |
I used a stack of washers so that the nyloc wouldn't engage, then removed washers after tightening, and ran nut down fully.
If that doesn't do it the tapers may be mismatched.
liam.mccaffrey
| posted on 1/5/14 at 02:27 PM |
Ok, have you considered whether the taper match is correct?!?!
In my expericene it shouldnt be that hard to seat a taper.
Build Blog
Build Photo Album
adithorp
| posted on 1/5/14 at 02:35 PM |
You def'need a way to keepthe pressure on while doing it up.
peter030371
| posted on 1/5/14 at 02:37 PM |
This car has been together before and these 4 ball joints fitted into these two uprights so I know its not that problem.
I guess I am being to wimpy and need to man up to it
liam.mccaffrey
| posted on 1/5/14 at 02:45 PM |
I would slot the tops of the thread for a screwdriver. There is no real downside.
Best of luck with this...let us know how you eventually sort it
Build Blog
Build Photo Album
