Matt21
posted on 16/5/14 at 08:32 AM |
Tyre pressure - slicks
what sort of pressure should i be running in slicks?
its only for trackdays, not racing, so just a rough idea would be great
thanks
minitici
posted on 16/5/14 at 08:46 AM |
Depends on manufacturer, construction, size, vehicle mass and many other factors.
Best ask the manufacturer of the tyres
minitici
posted on 16/5/14 at 08:50 AM |
As a guide, we ran the Radical on Avon crossply slicks
7.2x20-13 fronts at 13 psi cold
9x21-13 rears at 16 psi cold
Andy D
posted on 16/5/14 at 09:08 AM |
I run used Michelin slicks on my 580kg car. Usually start about 18psi cold, and after the first decent track session, come in and asap, drop them back
down to 18 to 20 psi hot. Then just keep an eye on them through the day.
mark chandler
posted on 16/5/14 at 09:09 AM |
I start at 12 - 13 psi, as they heat up they end up around 16 - 17 psi
I then check the temperatures across the width and add or drop a little to make this even across the width during down time.
