<<  1    2  >>
Author: Subject: Metric polybushes
drt
posted on 18/5/14 at 09:41 PM Reply With Quote
Metric polybushes
Hi guys,
I am searching for a supplier of Metric (M12) polyur. Bushes.
The rallydesign PB121/122 are 0.5 inch (12.7mm)
So are most (if not all) on Ebay...
Checked all the most used kit car parts webshops...
And MK has them om their wishbones, but can't find them on the webshop.
thanks
iank
posted on 19/5/14 at 05:32 AM Reply With Quote
Originally posted by drt
Hi guys,
thanks
Just because MK has M12 bolts doesn't mean they don't use 1/2" crush tubes.
[Edited on 19/5/14 by iank]
Anonymous
Slimy38
posted on 19/5/14 at 07:16 AM Reply With Quote
Mine were M12, or at least they're a good fit on the M12 bolts I have. Unfortunately the supplier is no longer a user on Ebay, but these are similar and they specifically point out they use a measurement that is closer to 12mm;
Haynes Roadster Locost Wishbone Bush set - Rear in Black Polyurethane
Minicooper
posted on 19/5/14 at 09:10 PM Reply With Quote
These bush/crush tubes are for 12mm bolts, the crush tube is mild steel zinc plated and not stainless as they are supposed to be but other than that they fit the 12mm bolts pretty snug
Haynes Roadster Locost Front Wishbone Bushes in Poly
drt
posted on 20/5/14 at 12:24 PM Reply With Quote
Thanks guys
I saw all of these articles.
They all stated 12.5 or 12.2 mm.
That put me off.
Slimy38
posted on 20/5/14 at 12:43 PM Reply With Quote
Thanks guys
That put me off.
12.5 I agree might be a bit much, but why are you put off by 12.2? The movement in the bush itself is likely to be more than that? I'd have thought you need to go for rose joints if you want things to stay exactly where they are.
Or is there another reason why you want the tolerances absolutely spot on?
I think mine are 12.2mm but there's virtually no lateral movement. To me the gap is just enough to allow a thin smear of copper grease so the bolt can come back out in five years time. Any closer and I suspect I'd have trouble working with them.
loggyboy
posted on 20/5/14 at 12:51 PM Reply With Quote
Any reason for sourcing 12mm bushes over sourcing 1/2 inch bolts?
Mistral Motorsport
drt
posted on 20/5/14 at 01:02 PM Reply With Quote
Oh and,
A m12(1,75) bolt has a production tolerance between;
11,966 and 11,701 mm
A 12.1,12.2mm crush tube will not do.
loggyboy
posted on 20/5/14 at 01:26 PM Reply With Quote
If your that concerned with tollerances you should be looking at rose joints and rod ends.
Mistral Motorsport
drt
posted on 20/5/14 at 08:10 PM Reply With Quote
The chassis end of the Wishbones are rod ends...
This is the hub side...
drt
posted on 20/5/14 at 08:14 PM Reply With Quote
Good point,
The used upright (hub) uses an M12 bolt.
retapping might be an option-ish
DIY Si
posted on 20/5/14 at 08:46 PM Reply With Quote
What do you need polybushs on a hub for? Every one I can think of is either a ball joint or a bolt..... And even if they are designed for a bush, if you've got rose joint inner ends, poly outer ends seems a bit odd as it will just introduce movement where you don't want it, especially if you're that fussed about a 0.5mm tolerance on a crush tube.
Sun Tzu, The Art of War
drt
posted on 20/5/14 at 09:12 PM Reply With Quote
What do you mean by a bolt ? Just a bolt in a tube welded to the Wib (wishbone)?
Then... :p I could have guessed it woud come to this ...
Rose joints, rod ends... if they are the threaded shaft type, so not uniballs.
must never be use in shear !
To do so is a bodge (and a sin)
When I move from pull-rods to push-rods -directly on the hub- than its ok.
Seems that is the best solution
drt
posted on 20/5/14 at 09:13 PM Reply With Quote
I agree fully on the extra movement.
eddie99
posted on 20/5/14 at 09:15 PM Reply With Quote
Also on the lookout for metric polybushes...
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
drt
posted on 20/5/14 at 09:23 PM Reply With Quote
metric
Haven't got any luck yet...
currently my hope is floflex.
http://www.floflex.co.uk/
DIY Si
posted on 20/5/14 at 09:36 PM Reply With Quote
What hubs are you using? It sounds like nylon, or a similar hard plastic, may be better for you than poly bushes as they'll remove 95% or more of the movement but still allow rotation.
43655
posted on 20/5/14 at 09:48 PM Reply With Quote
any access to a lathe? you can buy polyurethane bar, usually 90 shore A i think.
I'm considering getting some for bushes. i'll use delrin or nylon of somesort in my tube chassis wishbones though.
Would that be any good, if you want to have a precise suspension setup. would guess they'd be between poly and shperical bearings
drt
posted on 20/5/14 at 09:49 PM Reply With Quote
Without a crush tube ?
But how would I torque the bolt up without causing stiction ?
DIY Si
posted on 20/5/14 at 09:59 PM Reply With Quote
Nylon bushes still need a stainless steel crush tube. They look just like a poly bush set up, but with virtually no play.
My first version engine mounts use nylon, as I have very tight clearances, and they look like this. Just need to fit the stainless crush tubes now, as the one pictured is mild steel.
drt
posted on 20/5/14 at 10:17 PM Reply With Quote
aaah, I see.
Yes a PA66 bush would be the dream
Sadly I lost access to (my) lathe.
That is why I needed a supplier
Why do you have nylon engine mounts ?
DIY Si
posted on 20/5/14 at 10:25 PM Reply With Quote
Mainly because I had nylon bushes lying about ready for my front suspension. But that's weeks/months off yet, and I didn't want to wait for anything else to arrive in the post. And I only have about 1/2"-3/4" clearance in places round my engine.
DIY Si
posted on 20/5/14 at 10:26 PM Reply With Quote
And my bushes and brackets came from Russ (?) at Furore Cars.
drt
posted on 20/5/14 at 10:30 PM Reply With Quote
Aaah thanks,
didn't think about furore
(Do not wish to be a pain, a rigid connection to the engine would have been sufficient.
as the nylon will not damp anything out)
DIY Si
posted on 20/5/14 at 10:38 PM Reply With Quote
I know, but it gives me a little wiggle room on the bolts. They are also just a Mk1 engine mount, so I can change the bush later on with little hassle.
Also, try this place. They appear to have a minimum order of £50, but their prices seem much cheaper than anything else I've found. Ones the same size as mine are £0.48 EACH, but they do come in bags of 100!
<<  1    2  >>
