Author: Subject: Electric brake vacuum pump??
r1_pete
posted on 9/6/14 at 11:29 AM Reply With Quote
Does anyone know of a diesel car / van, which uses an electric pump for the brake servo? When I fit my ITB setup, I was thinking such a pump could be a viable alternative to tapping the runners.
posted on 9/6/14 at 11:36 AM Reply With Quote
Unlike fitting a vacuum gauge for a servo you only need to tap one of the runners, just make sure the non-return valve is effective.
DW100
posted on 9/6/14 at 11:40 AM Reply With Quote
Most diesels run a mechanically driven vacuum pump.
Hybrids run a electrically driven pump for when the engine isn't running
40inches
posted on 9/6/14 at 02:55 PM Reply With Quote
Early petrol SAAB 9-5, around 1998/99 had electric servo vac pumps. May have only been the auto box models.
posted on 9/6/14 at 06:39 PM Reply With Quote
Some of the supercharged Mercedes use a small vacuum booster pump in the servo pipes
